xmprx
- Jul 15, 2018
Just finishing up getting my Hardinge Cnc set up, after days of hunting down the 1 loose wire that was causing the jog function to halt, it is now up and running. I have never worked with a collet closer and I am a little stumped. the knurled nut on the end that I assumed was attached to the draw bar has set screws drilled through it. how the hell dose the collet release? also the rotary shaft or "clutch" has 2 air lines. both line cause the collet to actuate to the closed position. I am hoping someone on here is familiar with this set up or something similar.
thanks!
[/IMG]
[/IMG]
thanks!
