Hi folks,
I've got a new-to-me Harig 612 hand-operated surface grinder circa 1993.
The clear vinyl oil pump tubing is extremely hard so I would like to replace it before I put the thing into service. There's also a fair amount of schmutz between the way cover leaves which I would like to clean if possible.
Does anybody know if the tubing can be replaced without removing the motor and/or spindle?
I can peek under the front way covers and see the top of the column. The rear column cover is glued to the bottom of the column with silicone and blocked by the motor. I can't remove front or rear covers without spindle/ motor removal.
I've not found an actual service manual -- just the Installation, Operation & Manual which has no tear-down procedures. I gather these things were never intended to be serviced by mere mortals..
Thoughts about Cleaning and Tube replacement?
Regards,
Dave
Regards,
Dave
