HEALD vertical mill
thermite
Sorry to revive this old thread, but I'm having the same issue as the OP.
I recently acquired a Heald 1-V Vertical Milling Machine from a retired gunsmith. The machine is in good shape, but I've been unable to find much information about it. Does anyone have a copy of an owners manual? I did give the publications posted at VintageMachinery.org a peek, but I'm mostly interested in how to properly care for it, and what the spindle speeds are for the different belt configurations.
Thank you in advance!
I looked at TWO that were for sale years ago for $500 each. One was a vertical, the other a horizontal.
Such research as worked at all pegged them as "production line" critters - much as Burke, Barker, or Nichols specialized in, only better built and with far fewer options.
The compact shape and clean integration - similar to Sheldon/Vernon's wont, wudda been a plus as they took up very little floor or "shoulder" space.
Downside is stingy work-envelope.
If that work-envelope suits your needs? You've effectively gotten hands onto a decent alternative to a Hardinge TU/TM with the more powerful #9 B&S or 40-taper of a Burke or Nichols.
Simplicity, build quality, durability, maintainability should all prove to be top-drawer.
If no lube info, check other mills, there isn't usually much diff. Speeds you can calculate or just measure, HF or better tachometer.
steelhorse83
Aug 6, 2018
Omaha, NE
Thanks for the replies! I agree, it won't be quite a versatile as others, but I do like the compact footprint, and it will likely serve my needs. Bigger work will give me a reason to use my friend's J head Bridgeport.
Also, I found an outlet for Vacoline in 16oz bottles, which seems more appropriate that Vactra, since I'm not worried about coolant contamination. A couple bottles will last me quite a while.
steelhorse83
Aug 6, 2018
Omaha, NE
JohnMartin
Jul 8, 2006
Cumberland, Maine
Bumping this thread…is there any material on this mill that can be shared? I just acquired one.
Congratulations on a good purchase at a great price.
I don't know of any manuals, parts lists or operating instructions. I do have sales brochures and quotations for these mills, which I have scanned and have as files. Send me a PM with your email address and I'll send you copies.
Afk
Oct 9, 2022
John, Just sent you a message with my contact info
