powerglider
New member
I have a few heavy duty steel tables for sale or trade.
They were used for automation machinery bases.
Nice thick 1" steel plate. The one I have pictured is 62" wide by 113" long, the steel base structure is made from 4" by 4" square steel. This table also have leveling feet. One of the plates is in excellent condition, the other (under the plastic sheet) isn't as nice and shiny.
Located in Sarasota Florida.
I have 2 other steel tables of different size, these have 1" steel plate on them like the pictured one but use a lighter base structure with 3" by 3" square tubing construction. All have leveling feet.
If you only need the base structure or only need the steel plate that can be done. I can also deliver if you are close enough to my shop in Sarasota, Florida. You do need a way to unload.
