I think it's an electrolytic capacitor but can't tell the voltage/capacitance values. If you measure the voltage where it attaches, just pick a capacitor rated for a somewhat higher voltage. The value is probably not critical, so if you pick one with the same voltage rating and physical size, it will probably be close enough. Or look around the circuit board for an identical capacitor that is not damaged and get the values from that one. Usually manufacturers try to take parts from a bin of identical ones!
