Help me identify older surface grinder
mcskelle
Feb 1, 2021
Hi all.
I've had this surface grinder for a year and still havn't been able to identify it.
  • It features a gear driven mecanical movement of the table both in x and y axis. so no hydraulics.
  • All markings on dials a in metric system.
  • The spindle motor is inside the tower and below the spindle bearing which it drives with a belt. The spindle has just one rotational speed.
  • Has german writing on the on/off handle for the horisontal movement. german letters also on the manual magnetic table.
  • I would think the weight is around 800-1000kgs/1800-2200 pounds
  • It's bought in denmark.
  • The electrical box on the front is for sure quite a bit newer/retrofittet and is from danish company danfoss
  • The handle on the right move the table manually to the side, the handle in the middle move table in/out, the round thing on the left adjust the automatic movement distance from left to right, the round thing lowest, beneeth the middle handle, click-rotates in smal increments and seems to adjust the distance in the in/out movment per pass - but that does'nt seem to have any effect.
I've searched some local forums with no luck so far...
Does anybody have any clue?
kind regards
Thomas
mcskelle
Feb 1, 2021
Thanks Frank. Yes, sure I have, but it's an extensive website, so I get back and search now and and again.
But my info is so limited, that I have only searched and filtered on super broard terms like "german" and "grinder"...
So far, no luck for me on lathes.uk :-(
