Help need to tool change in front of part with out going home Qt250 Mazatrol 640
Dixon113a
Jul 15, 2021
Emporium
Hello
Looking to move away from part, tool change and go back to cutting.
Is there a way to do this on the Mazatrol 640 side. If not how can I use EIA in conjunction with the conversional side. Have 2003 QT 250 with Mazatrol 640 control. Could I see example of program?
Thank you
Josh
Hello
Thank you
Josh
Write a Mazatrol manual unit.
In Mazatrol parameter P17 should do what you want, it determines tool change position. There is a chart in the parameter manual that shows the different options, setting it to 1 would be X home and the Z clearance position in front of the part. The clearance positions are based on the tool lengths currently defined in tool data, it will move away to give room for the longest tool.
