Help needed, early Elliot Progress 4E drill press
MeteoMarsh
Oct 30, 2016
Greetings everyone.
I am in the process of restoring an Elliot Progress 4E, and I am having major trouble with the spindle and quill extraction.
First off some house keeping:
1) I have searched this forum for potential matches, my 4E is not built like the newer 4E’s or 5E’s for which manuals are available.
2) I have reached out to Tony at lathes.co.uk and he confirmed he had no matches for early Elliot 4E’s.
3) This press was originally owned by a blacksmith (not kept inside), which was then sold to a machinist (kept inside). It was not well prepared to handle exterior moisture.
4) This being a British machine, the use of the taper as a fastening type (and philosophy) seems to be everywhere. The down feed appears to have some sort of tapered, almost collet like appearance such that I was unable to extract it and had to extract the entire down feed shaft.
The synopsis as far as I can tell is this:
1) The quill is likely bound by rust to the cast iron housing.
2) the spindle has a gear at the top that should
3)Move freely along the keyway but does not.
I have tried:
1) penetrating oil, heat, percussion, induction coil, bearing puller(s) wedging, and it’s currently suspended from a gantry with heat and penetrating oil to see if it will break any rust bonds…
2) I am 95% sure i have removed all binding set screws or pins.
Pictures included.
Any ideas?
MeteoMarsh
Oct 30, 2016
I decided to flip it upside down and use a piece of aluminum, more penetrating oil, a large brass brush to spin in the bore… and it’s finally coming
MeteoMarsh
Oct 30, 2016
Got it! About 1 hour of dead blow hammering, wood hammering… oiling, swearing …. Sanding the exterior of the quill….
MeteoMarsh
Oct 30, 2016
Because there is little to no information on the 4E I’ll do my best to post a reasonable thread on its restoration.
