PackardV8
- Jun 4, 2006
- Spokane, WA
Yes, the following is not best science, but that train is out of sight long ago.
The workpiece is a rebuilt cast iron long block engine in which a .5625" diameter through hole 1.5" deep and 8" down inside the block must be reamed to .690" to receive a bronze bushing.
Since the engine is assembled and unwieldy to get back on a mill table, I'm hoping to do the operation with a piloted reamer in a hand held drill motor.
First thought, Make an arbor a precision fit in the .5625" hole, with a .500" or even .375" shank. Use the existing hole as the pilot, install the cutter above the pilot. Is there such tooling as a mountable end cutter .690" OD? If so, what is the nomenclature?
Second thought, More expensive; have a custom .690" extended shank reamer made with a solid .5625" pilot. Who would you go to for that request?
Third thought, Buy an extended length .690" chucking reamer and have the end ground to .5625" as a pilot. The quick search I did found some carbide tools for $250. Since this is a one-time operation, who would have HSS?
What other tools and operations would accomplish this?
Thanks in advance.
jack vines
Thanks in advance.
jack vines
