gargamel
- Mar 22, 2012
- Boston, MA
I am working on replacing spindle bearings in a ~1956 Cincinnati Toolmaster 1B. I'll post more thoroughly on the process later, but have run into a problem. Looks like the lock washer for the top of the spindle has the inside tab snapped off. Dammit. Thought i was being so careful...
I know this is a longshot but is there any chance that these are available somewhere? or that they are the same part used for another machine? From the service manual the key code is 6JJR-116, and the part number is 3809 as stamped on the washer.
Anybody know the size of the similar washer from a bridgeport? This one is ~1.185" ID and ~2.045" OD to the outside of the teeth.
In the event that I cannot find a suitable replacement, is there a reason that loctite would not work to secure spindle nut?
Thanks,
Mike
Thanks,
Mike
