Inquisitivan
- Oct 18, 2022
Hello all. This is my first post. I would like to thank everyone on this site as it is truly a wealth of knowledge. I have recently aquired a South Bend lathe. This was gifted to me by a friend. I have been doing extensive searches on the web and cannot seem to find much info on this particular lathe. The model is 420-YN. I don't like assuming things, so please correct me if I am wrong.
1. This is a early lathe that was made before the popular 9 inch lathes?
2. This lathe will be more similar to the "Junior" series of lathes?
3. Parts for the newer 9 inch lathes will not fit this version?
The lathe appears to have been modified. Several parts are missing, spindle gear, change gears, forward/reverse tumbler...am I missing anything else? My friend who I aquired only used the lathe for turning projects. I however, if possible, would like to safely use the lathe for threading as well as creating my own metric shaft size pulleys. I apologize if this post is asking for too much info at once! I'm just trying to figure out what I have first and then work on the availablity of parts. Any help is greatly appreciated!
