Hi all, I have two AC hydraulic 10/20 ton jacks the same style as shown on YouTube (how to repair your 65T air hydraulic jack. By AC Hydraulics) that were replaced in our workshop due to failing. I have one working again but it won’t be put back in service for lifting so I want to use it in a press.
While I can cut the jack body apart to keep the oil reservoir in tact and upright and I can mount the motor up the right way I want to invert the ram for the press. The ram is fed oil through a gallery between the motor and ram which is located between the three bolts that join the two together. This will require drilling and taping the oil passage in the motor body and ram housing so a hydraulic hose can be fitted but I need to know if this will work or do I need to modify the the entry point of the oil into the hydraulic ram and the return line. If I can get this sorted it will be perfect for an air over hydraulic press rather than tossing them in the scrap bin. Please see the YT video listed above to see how the jack is constructed and what I am trying to do.
Any help would be greatly appreciated. Thanks in advance, Stuart, Australia.
