Well, they do say that... They did make direct mount chucks.
But, if the chuck is a direct mount type, the screws should be what the factory put in, and ought not to have changed since then. Maybe someone "fixed it" later with some bodge or other.
The factory screw setup, whatever it may have been, would allow the desired amount of adjustment. That may only be 10 thou or so, and so no large clearances may be needed.
This all would be cleared up with just a couple pictures.
Are these flat-head screws put in from the front of the chuck?
Are they in factory countersinks, or are they bodged into counterbores, or crudely countersunk by some later person?
If the screws appear to be original, then the odds are pretty darn good that they are not the problem.
