historical arms
- Jun 15, 2023
Morning folks. New member here from Canada (Alberta).
I recently came to possess an old Hendey Tie Bar lathe from a neighbor farmer. He had given the machine to a local machinery museum but they refused it claiming "too big & heavy to move for them" so he offered it to me, his next option was to take it to a metal recycler for destruction and I couldnt bear that thought. I needed this big ol' thing like a hole in the head but now that it is here, and hooked to my wall power i might as well use it a bit.
I will have a meriad of questions for forum members that have/use a similar lathe.
First question, is purchase history still available on the forum for the machine, Ser # 14835.
I have found a couple PDF's manuals for Hendey's, on is for the same tie bar cone head machine I have but it is incomplete, the other is from much later (1940's) but still covers some Cone Head stuff.
My next questions both concern power feeds...1st, the threading chart lists 80 tpi as slowest transmision feed available but that is still 12.5 thou per rev. , is there a secondary feed source for fine feed of the apron? ....and how is it accessed. I suspect a change gear might have been supplied with the lathe but none are with it now.
2nd, both manuals allude to a power cross feed being doable but neither manual explain how to engage or disengage a cross feed???
