RCPDesigns:
It may take a day or two to go through the files to get the information you need about pulley speed and the drip cup dimensions. The cups are a two part assembly, the hanger rod and the cup proper. With all of the moving of my shop, I have had limited time do any research. When setting up your shaper, keep in mind that it has only two cutting speeds, unlike G&E
shapers from the same period, four in direct drive and four in Back Gear. Until the introduction of the Crank Shaper in 1914,
with its eight speed system, the only way to increase the number of speeds with a Friction Shaper was to increase the number
of pulleys on the Countershaft. The two speeds on the Friction Shaper were designed to take care of ferrous and non-ferrous
materials. The only difference between the various sizes of Pillar type Friction Shapers is that the larger models (24" and 28")
were equipped with Power Down Feed mechanisms. You will notice on your shaper that the table is hinged and that there is an adjusting screw at the bottom of the table to allow you to cut tapers.
Hendeyman
