Doozer
- Jul 23, 2001
- Buffalo NY
Some are confused by "gear feed in thousands" in that table. 100 tpi is 10 thousands feed. What am I missing?
I had to think about this. It does seem confusing.
The OUTPUT of the Norton box is
either to a Leadscrew (and then to the half nuts)
or to the Feedrod (and then to the feed clutch lever).
So if you divide it out, the Feedrod moves the carriage
4.167 times slower than the Leadscrew. So that is where
those feed numbers per rev come from.
Now the other thing the chart says is
Belt feeds equal one-half of Gear feeds.
This is because the INPUT to the Norton box is
selectable through the change gears from the spindle
OR a Vee belt coming from the spindle. So the belt
feed ratio is 1/2 the change gears feed ratio.
I once had a thought to replace the Vee belt with
a tooth timing belt and pulleys, so it would not slip.
That way you could cut threads twice as fine as
indicated on the chart. But 240 tpi might be useless.
The Hendey T&G lathe is an amazing machine.
So don't forget, the feedrod is 4.167 times slower,
so 120 tpi (in threading terms) becomes 500 tpi (in threading terms).
Change the input to the Norton box from gears to belt,
and that gets cut in half again, so the finest feed on the Hendey
becomes 1000 tpi (in threading terms) or .001" per rev.
Make some diffraction gratings anyone ?
So can one cut metric threads with the factory
Hendey Norton gearbox with the 24:48 (1:2)change gears ?
1mm would be double 13 tpi, or 26 tpi in this case.
So 6-1/2 tpi would be equivalent to 4mm pitch.
So my math is
1" / 13 tpi = .077" pitch
2mm / 25.4 = .079" pitch
1" / 26 tpi = .039" pitch
1mm / 25.4 = .039" pitch
1" / 6.5 tpi = .154" pitch
4mm / 25.4 = .157" pitch
1" / 17 tpi = .059" pitch (my Hendey doesn't have that one)
1.5mm / 25.4 = .059" pitch
A workaround is to set the Norton box to 4 tpi, and select the
feed rod (not the leadscrew), which gives...
1" / 4 tpi = .25" pitch
.25" / 4.167 (feedrod reduction factor) = .060" pitch
This works by leaving the bed feed clutch engaged
and reversing the spindle to rewind each threading pass,
because you are feeding with the rack, not the leadscrew.
1" / 20 tpi = .050" pitch
1.25 mm / 25.4 = .049" pitch
1" / 14 tpi = .071" pitch
1.75mm / 25.4 = .069" pitch
-Doozer
