Peroni
- May 18, 2007
- Yadkinville, NC
I picked up a 1953 Hendey 9x24 with the Reliance motor generator. I managed to get the unit running by swapping in a NOS tube. It starts right up, spindle runs forward and reverse and stops pretty quick too. But I'm having a problem with the speed control rheostat. I can change the speed fine but what the dial says and what the spindle is actually turning do not agree. I've tried getting them to sync with poor results. In open belt drive if I dial up 200rpm I get 86, 1000rpm gets 367 at the spindle and 2600 comes closer but still only 2327rpm. This lathe has the high speed range of 20 to 3000rpm. I can't run it up to full speed as one of the rheostats is damaged. When I hit the damaged are the relay circled in red will start to cycle, each time doing so it throws a large spark and the speed becomes very unstable.
There are two Ohmite rheostats used here. The diagram list a pair of model N 1500 ohm - parts number RRS1K5. However on this lathe I have a different one. The generator rheostat is as listed but the motor field rheostat is a spec # 34657 1400ohm unit. This is also the one that is damaged.
Someone has been in here before me as there are a lot of newer wire terminals plus the two rheostats are connected up with wire nuts.
At this point I'm not sure what the problem is. I can't say if the motor field rheostat was replaced in the past or not, it has certainly been in there for a long time. Or could my problem be elsewhere on one of the boards? Electrical stuff like this is my weak point and I also have no prior experience with a motor generator. My last Hendey had the mechanical drive and the 10EE's I used to run were either wiad or converted to an AC motor. I do have the wiring diagrams for this machine plus a good multimeter along with a brand new RRS1K5 rheostat that came with the lathe. Some guidance as to what might be going on and where I should start checking would be welcome.
