Thanks T, better than I expected to find a whole manual online like that. The differences in 800 and 801 that I see....the 801 has it's controls on a seperate pedestal and seems to have an Active DRO system. Also the 801 spindle motor is on top, whereas it pokes out the back on the 800.From the pictures, the machines seem rather similar.
Well since you mention it... I am curious about page 32, which seems to concern the oil circulaton of the spindle gearing. I'm mostly curious if that is a totally closed system or if it's a sort of splashing sump situation.You know I'll help you as much as I can with that weird language if need be .
I see no evidence of water cooling on the 800. Interesting the Hermle managed to cram all the electrical into the body of the machine (on the 800 anyway)...I have yet to pry open the panel to see how they managed that. The only modern* manual Deckel with electrics not seperate was the FP4MK and even that one had a rather large electrical panel bolted to the body.Water cooling? Seriously? The Deckel salesmen must have had a field day pointing out the disadvantages. I wonder why the designers thought they needed it. What is the top speed on this baby, 2,500 RPM?
Now that I have both Deckel and Hermle rotary universal tables in house I can tell you the Hermle one is actually more impressively built than the Deckel version. Tilts 45 degrees left/right and 15 degrees "nod" each direction.
Thoughts ?
Actually I was just assuming 15 degree nod both directions because I couldn't see the full scale...but now that I look closer at the Hermle manual it appears that nod is indeed 15/45 degrees.15 degree nod is not enough...Deckel unit goes full 45 in one direction and 15 the oopposite in the nod direction. Need most in nod because this is the direction that the head does not angle.....and the direction that favors the longest working axis "X" .
Looks like a nice unit...does it have indicators on all two tilting planes to recover the tram like the Deckel unit?
Looks to have a single lever rotation clamp as well.
What about multi gear rotation?
Feed joysticks....one for X/Y and another for Z. You pull one a little for feed in direction desired...pull it more for rapid. Can be intermittent or continuious depending on position of another knob. Vertical head has no power quill feed but does have fine feed and straight rack/pinion feed...very smooth action. Similar to Aciera F4/F5 in that regard.I like the feed switches (at least i think they are) for the axis...
And does the vertical head have a mechanical quill feed? Looks like it might.
Draw bars are different from Deckel....no need to remove "hat" on vertical head and horizontal is tightened/loosened on side of ram...both via special tool
Re indicators to recover tram, no...but neither does the Deckel "universally adjustable circular table" (stock 2037)...which is what I'm comparing it to.
Re clamp...has 2 rotational clamps, one each side...is that what you
Actually that photo is not a photo of my machine ! (when I started this thread I hadn't taken a picture...still haven't..so plopped that up so you'd know what I have) Mine has the identical table except mine has no indicator. I'll take a look tomorrow to see if it has a hole to accept oneSo if no indicators on the table what is the round object on the side of the table support frame shown in your photo..Just above the hand crank that appears to control the side to side tilt? Looks sort of like an indicator form here...
Nope, manual drawbar and manual axis locks on this one.The 801 manual so nicely provided (thanks Tien!) shows a hydraulic system with hydraulic drawbars and hydraulic locks for the axis travels. Is that the case here?
Notice
