Hi Feed Mill for 40 taper
70olds
Jun 21, 2016
What are you guys using for hi feed mills in steel? I am looking for something in the 1.5" range for doing 4140/4130 plate. One particular part is starting from 6" round and I have to remove probably 80 percent of the volume. I would like something I can run to helix down through a part as well.
OVodov
Sep 10, 2019
Mitsubishi/Hitachi Moldino High Feed works fine in our HAAS VF-5 SS.
We have 3/4" and 2.0" cutters.
I made a comparison between old Mitsubishi High Feed we used before, Kennametal and Iscar.
Moldino beat all of them.
Skubeesnak
Jan 14, 2014
Utah
Moldino are great . Though I have had trouble finding them since they changed to that name. where do you buy inserts and such? The web sight draws a blank for distributors. Only options I have found are China (not likely to be hitachi) or the occasional ebay find with three inserts. I have had good luck with the older iscars but inserts were 30 bucks a pop. Shars has a reasonably similar tool to the Hitachi iasr but the inserts are only sold in five packs and are out of stock quite often.
OVodov
Sep 10, 2019
Our vender sales them and he says it's his bread and butter.
I'm in Ontario Canada if you need contact of my vender, let me know.
ARB
Dec 7, 2002
Granville,NY,USA
I've had some solid luck with a HRMD tool from Korloy. I run a 2 inch in P20 mold steel. Worked well in my anxient 1994 VF3
