High pressure air motors
Cole2534
Sep 10, 2010
Oklahoma City, OK
Have any of your guys ever worked with high pressure air motors? I have a kooky idea that needs an air motor that will tolerate a case pressure of at least 250psi, preferably more like 1000, and develop about 10hp. I realize this is welllll beyond most shop air systems, but I've seen these before in use with other compressed gases so I know they exist... I just don't remember who made them.
For the sake of conversation, efficiency isn't part of the equation.
Philabuster
Jul 12, 2006
Tempe, AZ
Why 1,000 PSI? What output speed and torque do you need? Lots of pneumatic motors already exist on the market. Air motors are very inefficient compared to almost anything else.
Link to sizing a pneumatic motor:
Cole2534
Sep 10, 2010
Oklahoma City, OK
1,000psi is a common working pressure in this app, it'd be good if I didn't need pressure protection. Also need the downstream side good to 250psi. I'm using the differential pressure across a compressed gas system to drive the thing, inefficiency of the motor is inconsequential to the system's energy.
I can back solve for exact details, but I'd like it somewhere close to a 3hp 3600rpm motor.
IR lists all their motors at 90psi for performance data, and I can make 90psi differential work, I just need the case to be able to hold at least 250psi.
Garwood
Oct 10, 2009
Oregon
The ship's power plant I worked in used air starters on 16v149 Detroits fed from a bank of 5000 psi cylinders. It's been 20 years, but I want to say the starting air was reduced to 250 psi.
Bill D
Apr 1, 2004
Modesto, CA USA
How does an air starter work. Is it like a electric motor or does it pipe air into the cylinders to crank the engine. I understand the car engines that shut down at stop lights seldom use the starting motor. Once the engine is hot, to restart they just fire the ignition in the cylinders that have a load of compressed fuel and the piston is headed down. If that fails they turn on the electric starter motor. Older cars had starter motors that ran full time as a generator. Some Chrysler products reversed polarity to the starter motor every start to theoretically eliminate/reverse brush and commutator arcing wear.
Bill D
Cole2534
Sep 10, 2010
Oklahoma City, OK
On the bigger engines I've been around (Cat 35xx/36xx in NG Compressor service) an air starter is used directly in place of an electric starter. We do this because we have an unlimited supply of natural gas to spin them up and don't have to worry about batteries.
neanderthal mach
Dec 18, 2008
princeton b.c.
When I started mining in 1980, the V 12 haul truck engines were already 10 yrs old. Electric starter motor technology got better, and at least in mining and with larger diesel engines, those air starters are seldom seen now. The hydraulic shovel I was operating about 8 yrs ago had a pair of V16 Cummins with the usual 24V electric starters. I suspect there's an engine size cut off point where those air starters are still the standard and most economical starting method. Only a rough guess, but for what the OP wants for developed HP and operating on higher than usual shop air pressures. If anyone's using anything like it, probably the oil refining industry would be his best bet. But finding something used in or around his Oklahoma / Texas area might not be all that tough.
Cole2534
Sep 10, 2010
Oklahoma City, OK
Not oil, but natural gas in this instance.
EmGo
Apr 14, 2018
They have both kinds. Usually the air-into-cylinders is for the big big engines. Also there's spring starters that you have to wind up first. Sometimes the air and spring starters are for environments where you can't have sparks. Other times, maybe you already have a ton of compressed air and may as well use that.
Robert R
Aug 27, 2005
Raymond , CA
Turboexpanders are specifically made for your application. These four companies make units as small as 3KW coupled to high speed generators or compressors.
Should you become more ambitious here are a few examples ranging up to 20 MW :
Cole2534
Sep 10, 2010
Oklahoma City, OK
Very aware of expander options, we use them frequently. Thank you!
