Hitachi Seiki HT20SII CNC Lathe and is in need of your help due to an turret fault
SBeg
Sep 5, 2023
Hitachi Seiki HT20SII CNC Lathe and is in need of help please due to an turret fault.The current issue is specific to the turret when calling for a tool via program or MDI. The turret will index fine manually via buttons on front control panel however, when using program of MDI, it throws the machine into an fault condition.
We would like someone to help us get this machine up and running as soon as possible and if you are willing to come to our site to help us we can discuss the details as well.
I look forward to your replays and thank you in advance.
Dan from Oakland
Sep 15, 2005
Oakland, CA
It might help to tell us where you are located if you want someone to stop by. Also, some contact info might be help full as well.
Was the machine running ok prior to this issue or??
SBeg
Sep 5, 2023
Thanks for replay Dan
We are in Syracuse NY, and fill free to call (3 one 5) 4 six 8-6 two 5 one Ext: 147
The machine was bought/installed/leveled and when we started the machine for the first time everything turned on as it should. The head turns, the torrent with tools rotates manually. When we start the program for the first time machine stopped on the program when the program calls for tools to change and shows a turret error that you can see in the pictures i provided earlier in my previous post.
Thanks for your help
wmpy
Dec 16, 2011
What code are you using to index the turret? I believe that if you wanted to index to turret position # 5 on that machine, you would command T0500. This machine does not use the typical T0505 format.
Dan from Oakland
Sep 15, 2005
Oakland, CA
The control should display an error code along with going into e-stop. Can you access the error code page in the control and look up the error in your operators/programming manual?? Is this a new program or one that has been run in the past? Are there any old programs in memory that you can refer to? Do you have a programming manual for the machine/control?? As wmpy notes above, is your tool call format correct??
SBeg
Sep 5, 2023
I'm sorry, now we have another problem with the same machine, we can't get to the operating screen, the screen shows a battery error, I don't know where the battery is - picture is attached below
SBeg
Sep 5, 2023
Thank you for your reply. The code for tool five was T0500 M41 in the same line. Now we have a new problem with the battery (see attached picture) and I'm not sure if this fuse related somewhere or if the battery is somewhere on the PC board I need to find where it is. When I opened the back panel I saw a small LED code "E7 NC Emergency" I guess this is all related to the same cause. I am grateful in advance for any help
SBeg
Sep 5, 2023
Thank you for the replay Dan,
we are not able to reach the error code page right now because we have a new problem with the battery (see my last post with a picture)
the program we started is not new and came in memory. we have a programming manual for the machines and I remember the tool line was T0500 M41.
I appreciate any help in advance
atex57
Sep 6, 2006
SW Wisconsin
My ancient Hitachi with a 3T uses two sets of batteries. The set on the Fanuc front panel uses three D cells, the Seicos in the back cabinet uses two AA cells. What does your manual say about them?
Ed.
wmpy
Dec 16, 2011
I never put another code on my tool call line, but maybe it works. Once you get your battery situation straightened out, you might want to try getting rid of that M41 on the T line. M41 is most likely to specify the high-speed winding of the spindle motor. You can put it on a separate line.
It's been a while since I had a SII machine, but on the newer SIII machines, the battery is on located on the main board of the control in the back of the machine.
It sounds like you might have more than just a battery issue going on, though. I recommend contacting Cyber CNC in Wisconsin. They are pretty knowledgeable about these machines.
SBeg
Sep 5, 2023
yea, I will try to move M41 to line below soon as I get battery issue solved.Thank you for recommendations I may end up contacting someone form outside our facility bc time is money :) wmpy, thanks for your help!!
SeikiCorp
Jun 9, 2022
Phoenix, Arizona
The battery is behind the computer card cage in the cabinet.
It will be a couple of alkaline batteries in a plastic holder.
It may be behind or pulled out from behind the cage depending on who changed them last.
They have a short cord attached.
Change the battery with the CONTROL ON.
SeikiCorp
Jun 9, 2022
Phoenix, Arizona
After you fix the battery, Here is the SUM CHECK ERROR CLEAR procedure.
  • MICON16-2 PC Sum Check Error Procedure.pdf
