IHateMayonnaise
- Jul 17, 2016
- Albuquerque
Howdy folks,
Like many of you, I pride myself in being an accomplished remover of stuck things. One component on my HLV-H rebuild is giving me difficulty, however: the housing which holds the bed lead screw bearings on the headstock side. It is certainly a separate component, but I can't find it listed in any of the parts lists from Hardinge. I actually only want to shift it inwards about 1/8" (until flush with bed), and I only want to do this because I believe it will be tricky to paint around, and it's in a very visible location. I haven't used heat, because of the proximity to critical surfaces. I tried to press it out, and couldnt get it to budge with "reasonable" pressure. I'm not generally concerned with deformation of cast iron parts after applying pressure differentials, but I am being extra careful with this most critical of components. There doesn't seem to be any retaining mechanism keeping it in place (set screw, retaining ring, etc), I believe it is press fit.
Has anyone tried to remove this element? Words of wisdom, etc? Am I overestimating the difficulty in painting around around the protrusion?
Cheers,
IHateMayonnaise
Cheers,
IHateMayonnaise
