"HOIST" Fork trucks?
  • Thread starter Ox
  • Start date
  • Replies 57
  • Views 5,494
DDoug
Oct 18, 2005
NW Pa
Local rigger has a few. One is a 40/60 other is a 25/35. Said the 40/60 was a couple hundred grand. Little 4 cylinder, everything run off hydraulics.
Nice machines.
Sent from my SM-N960U using Tapatalk
This pix is a good one, looking over the operators shoulder.
Note the lack of view thru the mast ?
Note the general "squareness" of the operators station ?
Not really made for all day running in a warehouse, and having to jump on/off
10 times an hour.
That's where hyster shines, upto IIRC 15k
They have their niche, mostly riggers, and other specialized work.
Mr.Green
Apr 20, 2011
NE Indiana
10 times an hour.
They both have remote controls if I remember correctly.
He let me play on one, nice machine.
Can't see the end of the forks or back corner, but thats why you have spotters, or the remote control. [emoji38]
Ton of power, he hauls them on a step deck with a hydraulic tail. Damn things power right up them, set the brake halfway down once, turned it off a walked away. I was impressed.
DDoug
Oct 18, 2005
NW Pa
Yup, they would not last a day trying to load/unload 53' trailers at a depot.
Very special usage, very highly priced as well.
Mr.Green
Apr 20, 2011
NE Indiana
I am currently fixing a 12.5k riggers special hyster, that someone thought they could hop on and beat around a warehouse.....
Poor manual transmission. Almost killed the lift, well technically its still dead as I wait for parts to be found.
m16ty
May 11, 2016
I've seen them in marinas/boat-yards/boat rack storage yards. Rather than the travel-lift scheme used for larger boats, they just put really long forks on them, and one presumes a pretty long load center rating. But a lot of boats in yards aren't all that heavy. I'd swear I saw one that could lower the carriage really low too (to set a boat over seawall) but cannot recall how that possibly would have worked.
Another cool thing is the forks will go negative, to launch or retrieve a boat off the sea wall and reach down into the water.
thermite
Mentioned. Arredy. Reach down has been.
You don't really want to know what can be done with a rig like "Glomar Explorer", do yah?
Just not so much on dry land. Ordinarily..
Then again? There's always hunting for interesting vittles...
http://nesowea.org/wp-content/uploads/2019/09/Crayfish-of-Ohio-NEDO-light.pdf
Feisty buggers. Prone to charge when wounded, too!
Have a care!
:D :D
m16ty
May 11, 2016
Here is our Hoist 60/80, setting an injection molder.
Ox
Aug 27, 2002
West Unity, Ohio
What doo you mean by that?
It needs rebuilt?
It's a junky design/model in the first place? (the tranny)
You would prefer a slush box?
I am a HUGE proponent of a clutch on rigging machines especially, but I prefer a gear grinder in most any work related application.
I have a rented 15.5 Hyster out here right now that is only 5 years old, and it is REALLY nice!
(It is possible that you work at the fork truck rental place?)
But not as nice as if it was a gear grinder.
I will always gravitate towards the clutch for anything beyond a daily driver.
But they are hard to find anymore.
I am sure that is part of the reason that I picked up my 8K Hyster so cheap:
A) The dealer said that 8K is a "tweener" class rig, and was too big for daily chores and too small for heavy chores.
B) It's got a gear drive.
I LOVE IT!
Think Snow Eh!
Ox
Mr.Green
Apr 20, 2011
NE Indiana
It needs rebuilt?
I LOVE IT!
Think Snow Eh!
Ox
Snapped a shift fork and ground off two gears. Takes a special kind of idiot to do that.
bryan_machine
Jun 16, 2006
Near Seattle
I will note that after seeing "boxcar specials" on here, I acquired an 8K boxcar special (toyota, used). Maybe the sweet spot for biggest lift in smallest total length? Also the sweet spot for "if it's bigger than that I'm going to call the riggers anyway..."
It's an automatic but has a funky "clutch brake" pedal - which I never use, I just step on the brake, shift into neutral, rev as needed.
thermite
My most favouritist EVER was a dual-wheel pnuematic front, de-facto "tricycle" rear 4K "Towmotor" short-mast, short fork, that could actually manuever a load INSIDE of a 'nam-era GI "CONEX" container.
Lower overhead those containers had than the containers that came along to dominate, as we use globally, NOW.
We loved the combo clutch/brake instant feather-touch, fast adaptability as all-hands learned to use it expertly in short-order, and that it managed to deal with wet and greasy "laterite" soil of the gas cylinder storage area when even RT monster gummy-boot FL's got dodgy.
The mid-sized 4,000 and 6,000 "Anthony" fully-articulated Rough Terrain FL's were like having an extra long pair of arms. Or even octopus tentacles.. but it was the humble little Towmotor as moved a high multiple of those steel O@ and Acetylene cylinders, 24 X 6 or 7 X 365, and on ignorant standard forks, yet.
ONE accident, 12 months of round the clock working, it was that user-friendly.
Tired operator caught the tip of one fork under the edge of the 10-inch main storage slab, ran the load of 7-cubic meter O2 bottles up.
Fork took enough of a spring-bend, ass-end counter weight came off the ground, that when the concrete spalled it heaved a 153 lb O2 cylinder high enough and hard enough to clock a 6-footer right square in the mouth and bust two front teeth!
Scottl
Nov 3, 2013
Eastern Massachusetts, USA
As others have said, the HOIST trucks aren't for moving stock around a warehouse but for more specialized uses. The visibility THROUGH the mast is lousy but you get used to looking left or right of center as needed. The HOIST type machines are often used on jobs with where an assistant guides the operator anyway. That massive mast allows a lot of lifting capacity in a relatively small machine.
Not a warehouse workhorse and never meant to be.
SVE Performance
Mar 21, 2007
Milford,Ct
Silent Hoist was originally manufactured in Brooklyn NY they also had a plant in Milford CT from when they bought up Milford Crane and Machine. I used to walk by the Factory every day going to school during the 70's and remember all the different machines they built . Bill
m16ty
May 11, 2016
This is true. On the FR series, you can't see hardly anything off the right side of the lift, and can't see much behind you. We have a reverse camera on ours, but it doesn't help me much. The picture is good, but there is no depth perception. They are made to use with at least 1 spotter. It's just the price you pay for the compact size. To make the machine compact, you need most of the weight to be in the back where it can do the most good, and you need the machine as low as possible also, so you have to put the engine beside the operator, and have the operator sitting low.
Also, on the FR series, being hydrostatic drive, the oil will get really hot driving it for long distance at higher speed. They are built to go slow and smooth.
adamm
Sep 19, 2008
Kingston, ON
In addition to the FR series already talked about, Hoist also make large "material handling" lifts. I was in a factory whose product was ~16 tons/piece. They had a Hoist brand forklift for that purpose. Looked just like a 5000 lbs propane warehouse lift, but huge.
I LOVE IT!
Think Snow Eh!
Ox
That has me curious. Anyone know when Hyster stopped making manual transmission machines in that weight size? The first forklift I ran was manual, but I suspect it was probably from the 60's. When I was bought my forklift, I didn't see any manuals for sale at all.
