Holding over length tube for turning ( with pictures!)
hvnlymachining
Jun 21, 2019
St.Onge
Since this comes up so often in the forum, I thought I'd get pictures this time and post them up to give the newbies a visual reference for holding hollow tube at the chuck.
This is a new hollow chrome hydraulic rod I'm just finishing up, 2-3/4" OD x 2" ID x 104" long. And unfortunately too long for my lathe.
I made the expanding arbor to use a Morse taper as a wedge and a bolt through the mandrel to draw the taper tool tight. ( Yes, that's a chunk of old chrome rod) I had an old reamer with an MT3 taper with threaded base that fit, so I didn't have to build that part.
IMG_20240524_103424222_HDR.jpgIMG_20240524_103440401.jpgIMG_20240524_104743548_HDR.jpg
Also a pair of master thread gauges
(2-3/4" 12 UNF)
Since fitting the piston to the rod or vise versa would be nearly impossible.
These tools were from 4140 HT steel if anyone is curious.
Nicely done! Thanks for sharing.
Are you saying you used an old reamer as the cone to drive apart the arbor?
The slits look nicer than typical bandsaw work. Roll-in saw?
The reamer had an MT3 shank, which was already threaded for a drawbar.
The slits were cut with a steel cutting blade on my Cincinnati vertical mill.
They work surprisingly well with flood coolant.
