kvom01
- May 18, 2008
- Cumming, GA
Or, G-Wizard broke my tool.
The cut I was trying to make is an angled cut 3" long in that piece of 1/2" CRS. At the end, the side cut is 3/16". Endmill was brand-new OSG 4-flute carbide. I set it up to cut in 2 passes .25 DOC. Plugging into G-wizard for the maximum radial engagement, the program gives me:
2353 RPM
308 SFM
Chipload .003
Feedrate 28
However, because of the discussion in an earlier thread on chip thinning, checking that box ups the feedrate to 46 RPM.
So I ran the program at 46 IPM climb milling with the result pictured above (all 4 flutes snapped off). This happened on the second of two parts. I should probably have stopped as the finish was quite poor, but as these parts are just brackets they aren't critical. I used a tangent leadin, so no plunge cutting was done.
That 46 IPM looked scary before I started, but I decided to give it a try as a learning experience, sacrificing the $15 endmill as part of my education.
Any help on interpreting similar g-wizard output for future work would be appreciated. I'm thinking that in addition to the feed rate, cutting the full depth with just the side flutes might have been better.
The second operation on these parts was to have been a facing op across 75% of the piece with a DOC of .300" Using that same end ill with a .25" radial engagement, G-wizard recommends 26 IPM with no chip thinning. Does this sound about right? I'll have to use a 7/16 now which would bring the feed down to 23 IPM.
I could have done these parts with HSS both manualls and CNC, but I really need to get better with the F&S on the CNC mill using carbide.
2353 RPM
308 SFM
Chipload .003
Feedrate 28
