Bakafish
- Feb 21, 2022
- Tokyo Japan
Don't take the bait - not worth it. Focus on the task, not the distractions.
Agreed. Sorry for feeding...
While it would seem my post was 'off topic' for this forum which I humbly noted several times, you continuously imply that the quality of my post was poor. Your insulting gate keeping and needless disparagement over an unintentional infraction reflects poorly on you.
Sounds like an awesome project! Try to ignore all the trolls and snobs here. Lots of homebuilt machines out there making better parts than many 'professional' machinists running brand new hundred thousand dollar VMCs.
Your design looks pretty good. Aluminum extrusion will work just fine, however pay particularly care to how you connect to it. Assuming you aren't welding it all together you can lose alot stiffness in the joints. Also, since aluminum is not very good at dampening vibrations, you might consider filling the extrusions with sand and gravel. That would help with vibrations, give your machine some more mass and still be easily disassembled and disposed of.
Your spindle sounds incredibly heavy though. Does it have an ATC? Having that much mass up there is going to limit your accelerations, twist your bridge and generally make your life difficult. Might want to consider starting with just a *gasp* cheap router to start with while you get everything else working.
Something else to keep in mind is the noise this will generate. Its likey to run for hours at a time and make a ton of noise the whole time. Might want to look into sound proofing options.
What are you planning on using for controls?
You've mentioned that there is virtually no used machinery market in Japan. If so what happens to old machines? If they are just getting scrapped you could try and get ahold of parts off one. You can frequently find used linear bearings and/or ballscrews that are almost brand new for dirt cheap that way.
I don't want to start another flame war, somehow I'm guessing that controls are a source for such things. I'm a software engineer with a background in electronics, I will use open source hardware and software. I will detail it once everything is running.
Do you actually believe this ? Just wondering how delusional people can get and still function ...Lots of homebuilt machines out there making better parts than many 'professional' machinists running brand new hundred thousand dollar VMCs.
Au contaire, monsewer, I've been very helpful. Tried to turn the direction from a silly $1,000 USD hobby-shop speshul self-congratulation session, the kind that is specifically banned here, to something more high-performance and interesting. The fish (who has never run an nc machine in his life) knew better. So fine.Don't start. You've not been helpful here, don't make it worse.
So...Mr. Fish,
What have you actually done? You're telling us a whole lot about what you plan to do...have you actually done anything yet...drilled a hole or milled a slot, or anything? My experience is that these threads are all about CAD drawings and talk of which control board is best,etc, but when the rubber meets the road...it's all a bunch of smoke and mirrors.
Show me something you have done, other than fix a bathtub!
Stuart
If I get any more eased I'll fall asleep ! But that comment that people are doing better work with aluminum extrusions bolted together and stepper motors than with a new $100,000 VMC was beyond ridiculous. Maybe Mill thought it was sensible but you can push these claims too far, yes ? We don't want to discredit ourselves that much ?P.S. eg ease up a bit there bucko!
Notice
