How big of an insert drill in 316 Stainless can I get away with in this Doosan Lynx2100LB(8" chuck) what do you guys run in similar size machines?
PDF says 2.5" at about .0052 feed in what looks to be some sort of steel. I'd like to stay in the happy range where I won't greatly overload it or break something, other than hopefully break a chip... I assume I'll run out of Z trust before HP anyway. Can I go up to 2.25" or should I just get a 2"? hole finishes a bit above 2.5" 4.5" deep through holes, 145psi coolant I'll bore the rest. I'll mainly look at sandvik 880's and Iscar DR drills. Not much else available in my area.
thanks
thanks
