CompositesGuy
- May 30, 2009
- AZ
I need to detach this tiny (and crazy expensive) chuck from the shaft. The chuck was in good condition (Albrecht 0-1.5mm), but the hand feed needed some work. From some Google research it seems there is a JT0 taper between the shaft and the chuck, but I can't break it loose. I tried holding the shaft in a collet and hitting the backside of the chuck with a tiny home-made slide hammer. I also tried spinning the knurled part at the back side of the chuck, but that just spins on the chuck body.
