how far down can I bend the top of a South Bend 9 headstock bearing?
Dick McBirney
Oct 22, 2013
Maryland USA
I am a mentor for a local high school robotics team. They have a South Bend 9 lathe with 0.006" of headstock bearing play. Although I know there is a peelable shim that can be reduced in thickness to tighten the bearing, removing enough shim to decrease the clearance about 0.004" makes me worry about cracking the headstock casting. What is the maximum shim thickness reduction allowed?
chipss
Jul 19, 2020
Nothing to it. .006 is nothing for the casting to flex. Peel away and get the bearing clearance to a half thou on both ends.
Mechanixman
Sep 9, 2022
I just brought mine back within, or close to tolerance from abkhr double your bearing play.
Part of my process was removing the next shim in the lack, which was a .004 shim on each side.
I wouldn't worry about doing it.
4GSR
Jan 25, 2005
Victoria, Texas, USA
His bearing caps are not split into separate pieces. Yes, it is possible to clamp them down enough to break off part of the bearing cap. Since the bore is badly worn, accuracy is not a real issue, I would apply heat to the cap as it is torquing down to close up the gap. Don't heat it up to cherry red, but somewhere in the 800-900 degree range. Do this without the spindle in place. Let cool, then install the spindle and tighten the cap down to the clearance needed. Just my opinion on what to do. Ken
jmm03
Aug 8, 2004
ventura,ca.usa
with the appropriate size shims properly located under the cap wouldn't the cap pull straight down on the spindle and there would not be any bending involved?
chipss
Jul 19, 2020
Older 9's had removable bearing caps. His is this style with one bolt doing the tightening.
