How much does coolant toxicity matter?
Jrill
Feb 11, 2013
Northeast USA
I'm looking for your opinion and hard-earned wisdom here.
I'm shopping for a new coolant brand and I started looking at the SDSs, particularly for Castrol MB50 and Sterlingcool 77....
And yeah there are some ingredients in there that don't sound good at all.
I don't want to constantly expose myself and coworkers to toxic chemicals or have to worry if I get some in my eye by accident...
But on the other hand I think of those over-the-top "known to the state of california to cause cancer and reproductive harm" warnings on everything, and I think of all the way oil and paint thinner and aluminum oxide dust that I'm exposed to, and I wonder if some fungicides and TEA in coolant is really going to be a problem.
What is your take?
DouglasJRizzo
Jun 7, 2011
Ramsey, NJ.
Name brand stuff like Castrol or similar are not really that "dangerous" if used in accordance with instructions.
Most of those "Danger Warnings" are from people who tag that on just about everything.
EndlessWaltz
Jun 18, 2016
Midwest
Have used Oemeta, Hysol, and Blaser. Stay away from the Blaser. Hysol warnings on the can seemed to have an extra one (air toxicity?) versus the Blaser but seemed like I did better with that. Oemeta has no warnings on it. Have not seen issues with it. When ever I do a change over it seems like I may have a lean condition despite refract. This is with any coolant and may cause rust spots. The second I see that I dump in more concentrate and after a week I am stabilized. I still wear gloves either way. Dermatitis is real. If all are around the same price per 55gl I would go with Oemeta.
BT Fabrication
Nov 3, 2019
I talked with the chemist at Ometa here as he is just down the road about the technical side of there coolant and others. and he had stated that certain coolants you shouldn't touch with bare skin as there are components in it like chlorides that are terrible to absorb through the skin. He is one of those guys that knew what he was talking about and every little detail about it all.
I have just looked around again for coolants and found Ometa and using the suggested Novamet 900. which works pretty darn awesome. used to have Qualichem 230 and it cut parts nice but I was having a ton of issues with something in it when parts needed to be welded afterwards. Im guessing it was the oil ratio in it as the refrac index was 0.97 and as you move further and further from 1.00 to 2.00 gives less oil in the mix. I believe the stuff im using now has 1.27 refratometer ratio to it.
Jrill
Feb 11, 2013
Northeast USA
I've been using Hangsterfer's 5080 for about 7 years, and I love it. It's basically food grade. I mix it with distilled water, and it never goes bad or gets stinky. I've splashed it in my eye and it didn't even sting.
That’s awesome, ive been looking more and more at the 5080. So you have any problems with rinseablility? What materials do you use, and do you use anything besides tap water? Our water seems soft as far as I know, should probably get a test for it.
Jrill
Feb 11, 2013
Northeast USA
The Oemeta, did they have a problem with a bad batch or was that another coolant I was reading about?
mhajicek
May 11, 2017
Minneapolis, MN, USA
At my previous job we started out using tap water, which is extremely hard around here. We had rust and mineral buildup problems. Then we got a DI filter system and used only that, and all the problems went away. Now that I'm running a small shop in my garage I'm running a distiller to make my own distilled water for drinking and coolant.
As for materials, I run lots of Ti6Al4V-ELI, 17-4 H900, and a smattering of aluminum, assorted stainless, and occasionally 4140. Good performance, good rinsability so long as I don't let it dry on the parts. I highly recommend it.
DavidScott
Jul 11, 2012
Washington
The coolant concentrate is only a part of the possible toxicity, especially if the coolant has been in use for a while. Does it matter? Think about how much you ingest or absorb over a year breathing the mist and having it on your hands. Good ventilation, from the machine enclosure, and barrier cream make a massive difference in how much you are exposed to.
IninefingersI
Mar 9, 2022
Doo Dah, Kansas
Been using MB50 for years. Have no problems with it. I don't think the coolant is as much of an issue as what is in the coolant. Whatever coolant you use, if you let it get loaded with rancid tramp oil, bacteria, people using it as a spitoon, and God knows what other kinds of science projects are being cultivated in people's coolant tanks, it is going to be a problem. Clean coolant is happy coolant.
Jrill
Feb 11, 2013
Northeast USA
I’m trying to get a quote on it from somewhere local but haven’t had success yet… curious how much you’re paying for it?
EndlessWaltz
Jun 18, 2016
Midwest
So did you guys see that story about how they tested the pools in VEGAS. HAHAHAH. Off the charts with bacteria and E. coli. Makes you wonder..
