I need to remove the apron on this Takisawa lathe; the keyed driveshaft has what looks like a clutch of some sort in line with the shaft. I removed setcrew that was threaded partially into the collar AND shaft (between them) with a spring underneath. There is a roll pin and another pin in the unit, but before I go driving the pins out I figure I'd see if anyone has been down this road yet. Carriage must come off to replace the gear that engages the rack up under the front way, and the keyway in the shaft does not extend all the way to the tailstock end so I think I need to remove the driveshaft from the tailstock end of the apron.
