FirstAscent
- Nov 24, 2022
Hi everyone,
I'm looking for some tips on how YOU would clamp this part down in a vertical mill. I'm still building up my tooling and currently only have one vise for securing parts. I'm OK purchasing whatever I need to help with this but also trying to think ahead on what would work for this and potentially whatever else I might run into in the future. Versatility is key, along with high quality.
The actual work being done is very simple, you can see the existing threaded hold circled in red. I'm simply relocating the hole (drill, form tap, chamfer) about an inch closer to the large bore (where the red dot is) then will mill the top edge flat since there is somewhat of an existing raised edge where my new hole will go.
I want to make sure everything is secured down tightly though. Couple different angles shown below so you can see what I'm working with.
Material is Aluminum.
Good opportunity to look into some additional filtering/clamps/etc which always come in handy.
Thanks!
Thanks!
