SShep71
- Sep 17, 2014
- San Diego, Ca
It's tool box clean out time, bring stuff in and keep moving stuff out. I have a few lots of HSS endmills, these are all different diameters, lengths, and flute counts. Some are radius, some are angle cutters, all in good shape. I do not keep garbage endmills, they either get recoated, resharpened, separated, or scrapped. I recoat whatever I intend to reuse.
Lot 1
There is a total of 64 endmills here, the sizes range from 9/64 up to 1-1/4" (reduced shank). Flute count varies from 2 to 6, lengths wildly vary. The first three pictures below. $150.00 shipped CONNUS
Lot 2
Mostly brand new endmills (plus a few extras that were in the drawer). All the best quality, plus two from China. $100.00 shipped CONNUS
(2) Hertel 1x1x4fl
(2) Morse 3/16 x 1-1/4" x 3/8" 4fl
(2) OSG 8deg 59763 (lightly used for Alum)
(1) Niagra 3/8" x3/8"x1"x5"
(1) Niagra 3/8" x1.5 4fl
(1) Niagra 19/32" 2 flute radius (lightly used on alum)
(1) PCT 3/8" x 3/8" x 3" x4.3" 4fl
(1)Niagra 3/4" x 3/4" x 1-5/16" (never used, put in and removed)
(1) OSG 23mm 4fl
(1) MHC 5/16" x 3/8" 4fl china
(1) MHC 3/16" x 3/8" 4fl china
(1) Hanita 5/16" x 2" x 3/8" 4fl
(1) Niagra 3/8" x 3/8" x1-1/2" 4fl
(1) Hanita 1/4"x3/8"x1-1/4" 3fl coated
(1) PCT 3/8" x 3/8" x 1-1/2" 3fl radius
(1) OSG 10deg 59742
(1) OSG 10deg 59761 (lightly used on alum)
(1) International 1/8" x 3/8" x 3/8" 1/8"rad 4fl
(2) Award tapered endmill 1/8"x3/4" 3deg taper
(1) Richards 1/16" x 3/16" 2fl
(1) OSG 3/8" 7deg taper 3/4" shank
(5) random endmills along for the ride
Lot 4
22lbs of random endmills, reamers, drill bits, form cutters, etc. I had a large drawer of misc cutters. Never used any of it, I went through all of it years ago and separated all the junk out. The stuff that is here is in decent shape, not the sharpest but no massive damage. Perfect for someone in a home garage or just learning. $75.00 shipped CONNUS
yes lot 3 is missing I hit the limit and will post it later
Lot 1
Lot 2
(2) Hertel 1x1x4fl
(1) OSG 23mm 4fl
(1) OSG 10deg 59742
Lot 4
