Hello Guys,
this is very interesting thread for me. I came across with a nice Hydrovane 33 compressor, 40 years old but hardly used - only 663 hours. It was army stock. Looks like new. The problem is that last 10 years was stored and unused - i found the oil became an oil/water emulsion. I took apart unloader valve - bit dirty inside, after cleaning shoud run fine, safety valve looks like new. The problem is servo valve - i can't manage to remove valve sleeve from compressor body. I know there is one bolt from underside, locating the sleeve. I removed that bolt but the sleve is still stuck. Sleeve has internal thread, G3/8 so i screwed in G3/8 piece of rod and used gentle blows od reverse hammer. Not sure how far i can go with hammer blows. Do you know if there some other bit holding the sleeve down in place? There is some oil/water slug in side - maybe corrosion caused the sleeve to sieze? Any ideas? Thank you.
