Have narrowed one issue down:
Looked back in this thread a bit to see that the main issue noted here had been the "lost" turret. I don't know that I have had that issue since then. ??? I mean - it's definately been quite a while since I have seen that happen now!
What has changed since then? Well - the only thing that comes to mind is that (Now you REALLY aint gunna buy-in to this!) I am running my library on empty. I have had trouble on 2 diff Fanucs with files getting messed up and this particular one actually tied up so tight that I had'ta send it out to git "unlocked"! It was a feasco to say the least! (3 yrs ago)
Even since that excorsism I have had files git messed up. I have learned that if I keep my library emptied out that I don't have this issue. Could it be that [for whatever reason] this also played a roll in my 'lost' turret? It is too crazy to believe, but....
So - enyways - on to new business.....
I had thought that all my issues were relative to a common power supply. Nothing on the other supply was messing up. I assumed it was a weak capacitor as I was having troubles getting it to light up after the case had been powered down long enough to cool down. (caps to drain)
Well the issue has gotten to the point that I can't get the machine up at all now. We kinda got it narrowed down to a 24V issue. So now we are playing musical daughter boards, as well as switching to a diff 24V supply - but the meter read a good value, so ...
Have it nailed down to the daughter board on the one 2 axis Alpha amp that is creating the issue, with the same issue on a nother amp right beside it getting worse, but still able to clear the alarms yet if allowed to warm up a while. There is yet another amp almost the same with no issues at all.
My teckie found a small cap on the 24V circuit that looked like it could be an issue, and was easilly servicable. He gave it a 15-25% chance of fixing it he said.
It didn't...
There are three other little doo-hickies on there that one of them is likely the cuplrit - but they are not easilly serviceable. This board is very densely populated and he is not comfortable just throwing parts at it.
So - I called TIE and they did not have any reman boards to exchange. They priced me new, but didn't have that either...
I called Fanuc. This board has been superceeded to another number. But wait - it's not that simple!
The new daughter board won't neccessarily work with the current mother board! It is highly suggested to buy a whole new(sed) amp with the updated set-up in it.
Now I can't fuss aboot the price of the new(sed) unit from Fanuc, but I decided to call TIE to see aboot a complete unit as well. ???
Yep! They have the whole drive!
BUT! There's always a but eh?
BUT! (via TIE) There is a service bulletin from Fanuc (and they sent me a copy of it) you may need to update your SRAM to accomidate the newer drive unit. The SRAM has a $500 deposite on it. (for a flash card? It would seem that they could jist e-mail it to me eh?) I send it back - I git my $500 back. No biggy there.
But FANUC made no mention of this a'tall!
The next issue tho is that I have THREE of these on my machine! If I need a software reflash to change one of these - I hafta wonder if I will hafta replace ALL THREE?
So this is where 5:00pm Friday leaves my sorry assets.
Hopefully someone that has these troubles will be able to learn from my pain.
***Calgon - Take me Away!***
Ox
