I really can't believe a broken circuit. Once it is warmed/fired, it will be fine now as long as the power is kept to the case level. The lamps are not on the drives anymore. It is simply for start-up that it is an issue at all.
If it was a solder joint - I wouldn't expect two units to have the same issue, both slowly preggressing at same pace. Seems to be componant level to me. (Not that I know enything about it all.)
My techie said something about getting a new tester that should be able to read those little shiny ones better. He tried to bench test tham last week and none of his meters could get a logical reading on them.
Ox, chances are the drives are different. The base transistors (igbt's) are probably sized for a specific amperage output. You would have to see down deep in the guts of the drives to see the base transistors and other high-power components.
Now, if all the base components are similar, then the output difference would be in the circuit boards...probably just a setting or two..
Yeah - I would hafta start to really dissassmble the drives to get in to see more of the high power unit stuff. Everything that I could see all had the same values on them. That's why I kinda wonder if the D-board doesn't simply "know" to send a limited amount of juice to the smaller motors - rather than have that many more major componants to stock?
Could go either way really...
Think Snow Eh!
Ox
