Currently I am refurbishing a 1945 South Bend 10L Lathe. Model 8187ZN - Tool Room model with a single tumbler quick change gear box.
There is a single gear that has confounded me - can't find NOS, used ones are worn beyond what I have now.
Like a crazy person, I humored myself by submitting RFQ's to some commercial gear makers - Boston Gear declined, not worth their while, while others came back with prices that literally took the air from my lungs. (as in I could buy a new Grizzly 10" machine for the same cost)
The gear in question is the Tumbler Arm Idler Gear for the Quick Change Gear Box. I believe it is PT-605R1.
It is the style that is supported on both sides by the Tumbler Arm and has a pressed in needle bearing - Torrington GB-88 (.500 ID / .682 OD)
The gear measures out to the following dimensions:
2.062" OD
.682 ID
.275" Thick
27 Teeth
Pressure Angle 14.5 deg. (so I have been told)
Material cast iron.
I have been told it is a 14 Diametrical Pitch
Is there anyone out there has one to sell or can make this?
Making a gear is way above my paygrade.
Thanks in advance.
Scott
2.062" OD
.682 ID
.275" Thick
27 Teeth
Material cast iron.
Thanks in advance.
Scott
