I have two nearly identical products that need more speed than a standard engine lathe can provide but I don’t have the pockets or CAD skills to go CNC. It’s taking me longer than I care to admit on a standard lathe. Like 2 hours…don’t laugh my lathe is from 1942 and is a little anemic in the hp department.
Operations require spade drilling a hole of 1-1/2”x12” of 17-4 bar, threading, then flipping, boring out to final ID, then threading the other end. One end needs the OD turned down slightly and I think that could be done simultaneous with the spade drilling. The second product is just shorter.
Tolerances need to be .003” or better but I’d like to stay around half of that if possible. Is that realistic with a middle of the road condition machine? I’m prepared to spend some time dialing everything in to mitigate the operator for what it’s worth.
My reading of the available w&s literature has shown that QCGBs were available but are apparently tough to find. I’m seeing a few out there but the smallest machines I’ve seen with them are the 2A.
I want to keep as concentric as possible and have been single point cutting up to this point with good results. Is that silly to do on a turret lathe? I see there were single point threading drop slides made but not sure how easy those are to find these days.
So what is the consensus? Would a turret lathe fit the bill? I would love to do it all on one machine but if getting a 2A just for the QCGB is completely insane I could always go smaller and cut threads on a regular lathe. I’m just trying to cut cycle time down as much as possible.
