Used once, only on plastic. Light surface rust.Don't buy this! $800 on F'book marketplace, the horror!
I have a Bridgeport Clone with a new spindle motor and a set of collets and a drill chuck I would sell you for that much right now. The machine is wired for 220v 3ph but you can get a static phase converter for about $400 to run it off of 220v single phase. The machine I have is branded as "Manford", it is a Taiwanese clone of a Bridgeport. It had a Centroid controller on it that bit the dust and I am not going to replace it. So it is left with the servos on all three axes - which is a plus for some people.Hello, All.
Some background: I have a Horrible Freight lathe I bought 20 years ago for a project. Didn't use it much after that project until about 3 years ago I decided to mess with maching some rifle barrels. While the lathe is not premium, and I'm no machinist, I have successfully chambered and threaded barrels (yes, I got range rods and a dial indicator and grasped the basics). My most awesome piece (for me) is a 6mm barrel I chambered in 6x45 (.223Rem necked up to 6mm projectiles) then threaded and which I shoot through a Yankee Hill Turbo (22CF suppressor) without baffle strikes.
All that to say: I can get some stuff done even using mediocre equipment.
I want a mill. I've never laid hands on a mill. I don't know which brand/make/model to get. I don't need CNC, at least to get started. I don't know if I'd ever get into it enough to want CNC. I don't know which size to get. If I had a mill right now, I would be surfacing a 6" diameter aluminum circle. I'd like to be able to more-precisely drill holes in steel and aluminum. Using a boring head or a fly cutter to true-up and open up rough-cut holes would be desirable. I've read/heard of "power cross feed" or some such and I imagine that means the work table has a drive mechanism to move from one side towards the other to regulate material feed speed to the cutting tool.
I've read folks asking about Horrible Freight and Jet and Grizzly and the responses of "spend that money on a used Bridgeport or similar". My problems are: having zero mill experience, I don't know what I'm looking for to determine the quality/serviceability of a used unit or how to repair one if it's in need of work, and I'm in a kind of rural area, about 90 miles NW of Dallas so used equipment isn't likely to be nearby.
For a baseline, if I just picked one I'd looked at to give an idea of where my mind is, if I bought one right now (foolishly) without seeking input, I'd be buying the Horrible Freight Knee mill priced about $2,600.
Anyway, thanks for your time.
--HC
According to the Bridgeport sales brochures the older (circa 1970's) Series I machines with the 42" table and power X feed have a travel of 26 1/2". The machines with the manual X feed have a travel of 30"Gortons (22") and the nicer Bridgeports (36 and 42" tables) can't do that either![]()
Notice
