Terry Keeley
- Oct 18, 2005
- Toronto, Canada eh!
Is there a point where grinding it round, then lapping for size and finish makes sense?
It's got a very slight taper.
Yeah, I remember that now. That's the issue with sporadic threads, you lose your place.It's got a very slight taper.
Ha! "Crazy Quebecois" we call them, I should know, I married one.
I'm taking out about 0.005" per side.
Can't be any worse than china girls ...
That's actually kind of a lot for such a small hole. Doing 2" and 3" bores in carburized gears they'd usually clean up in about .003-.004" ) (total) then have a good .005" to get to size. Maybe drop back a little, or is the plating too erratic ?
About the photos, you carefully took them from an angle where we can't see but I hope you're using blotters, Mr Pilot Sir. Wheels without blotters is like coffee without cream and sugar, la zi ji without peppers, hamburgers without beef. It's just not right![]()
Looking for a super-polish, thinking the 90 grit AO dry will work but we'll see.
On one of the Ukrainian FB model engine groups there's a video of the bore being polished with a white cloth wheel and compound, the end result being a mirror finsh bore. I presume the finish was very good post grinding, so not much chrome was required to be removed in the polishing
Your quill looks pretty good. I would want the ID of the wheel hub closest to the wheel head to be a very tight (hand) fit to the quill nose diameter. I would likey use blotters on both sides of the wheel, and another blotter behind the wheel hub closest to the wheel head to ensure no steel-on-steel slipping.
I would solid-set my dresser diamond or grit dresser at .0005 from my finish ID size so I could safely rough the part too -.0005, so needing to play with only the last half thow., might spark-out at -.0005 and then go to finish size.
I would likely buy or have a grinding shop make a spare quill.
I would likely log my ID taper for a number of parts to see if a pattern existed so to play with my in-feed location and stroke stops to see if I could find the sweet spot that was best for size and straight..
I would likely set up a second machine with a hone so I might super finish, and straight finish size to .00005 when needed.
I would likely call Radic for wheel advice and try a white AO, pink AO, SC, CBN, and diamond wheel in that order.
Likely you are doing most/much of this stuff.
It sure looks like you have an excellent nitch business there.
Looks like Blind River, lake Matinenda will be making Ice next week, good.
Buck
QT; oP: The collets that came with the grinder (I called NSK to order a couple more but passed at $80 ea!)
I was once offered a 3-state sales region from NSK for NSK inserts. At that time I think they had the very best ceramic inserts.
I wonder If Sam Beto is still with NSK? (not sure if I spelled his last name correctly.)
Isn't Profi Ukrainian? I wonder how they are doing.
Got a link? I tried searching but came up empty handed. Some of the best model engine stuff has come out of Ukraine and Russia over the years, sad the current situation. I've been messaging a buddy on FB that makes his own stuff with very limited resources, he was in Kherson but had to leave when the fighting got too bad.
Do you want a super-polished finish or are the grinding grooves helpful for oil retention, like honing does ?
Ha! I better not talk about the cute China dolls around here in case my wife sees this and I end up like John Bobbitt!![]()
For once I sorta disagree with grinder buck ... if I can ever figger out this turbocad thing I'll have a project for you, flyboy.michiganbuck said:Your quill looks pretty good.
Notice
