JL Sargent
- Feb 7, 2005
- Birmingham, AL
This is a tip I recently picked up from another forum. If you dont use your engine powered welder for a while the generator portion of the machine (the armature) may loose its magnetism and therefore not excite the generating action.
One way to possibly reintroduce it is to take a basic electric drill, plug it into the generator and then by hand rotate the chuck the opposite way the drill is set to run while the generator is running. (if drill is in fwd position turn chuck in rev. direction). This will generate a small voltage which can get the whole shebang going again which will instantly start the drill running opposite the way you just turned the chuck.
