dgfoster
- Jun 14, 2008
- Bellingham, WA
(Please Note: While this thread will deal with fixturing my prisms specifically, I think it has application for machining other shapes that need similar flexibility in fixturing.)
In a recent related thread I reported I'd been working on the concept and execution of an improved workholding fixture to be used for machining the faces and top rail of my SE/Prism/Parallel/Level castings. These have proved very popular and about 1/3 of the people who purchase them want them machined. So, it became important to me to make machining of them faster and easier while still maintaining excellent flatness and parallelism of the faces and top rail.
Until now I had been mounting the prisms on two bolts fitted in the ends and supported by angle-iron fixtures on my mill table.
The general shape of the casting is demonstrated by the following 2 pics.
Please ignore the vertical Sharpie line drawn on the rear end of the sole below.
Here is a prism "skewered" on the bolts which are supported by the angle fixtures. The clamping straps prevent rotation of the prism on the bolts. They are placed rear (shown) and in front---not visible in this photo.
Spherical washers are placed between the ends of the prism and the angle fixture to reduce possible flexion of the prism due to bolt tension.
The red arrows indicate the location of the washers. And the front anti-rotation straps are seen in this photo as well.
This system has been quite satisfactory from a rigidity and stress-free point of view. But, its shortcoming is evident if one end of the casting needs to be raised or lowered to get the cut lined up with the casting's plane or if the casting needs to be rotated to get the second cut right at 45 or 55 degrees relative to the other face. In those cases, loosening one or both bolts puts all degrees of freedom into play---elevation of the end of the casting, fore and aft location, and rotation are all unconstrained. So, elevating one end can throw off rotation and fore and aft location etc. That was sometimes a bit frustrating as it could take a while to gradually get eveerything back where I wanted it. Admitedly, the fixture was easy to fabricate and rigid, but it ended up costing time in fiddling.
So, having plenty of time to think about solutions while autofeed moved the casting slowly under the face mill, I gradually devised a new method of work holding that allows adjustment of elevation, rotation, and fore and aft location. But, the new fixture isolates each factor so that only one degree of freedom is adjusted at any one time while leaving everything else as previously setup.
That is about enough keyboarding for one session. But I will post an image of the new system in drawing form and provide a link to anyone wishing to go into Onshape (No downloading of software needed and no spam will be received from the company) and view the drawings in full interactive 3-D imagery.
Onshape Link
This image shows the top block of the 3-block stack removed on the left so you can see the "ball joint" bolted onto the end of the prism and allowing for stress-free rotation, elevation, and fore and aft movement. All those holes will be explained later and setup of the machined pieces will be demonstrated in a brief video. By the way, the pale blue long thin bar is just a stand-in for my mill table for this illustration. It is not a part of the actual fixturing system.
The block stacks have been machined and assembled and will be put to the test tomorrow when I machine an 18 for a member here who is patiently standing by while I work this out.
Here are the machined pieces with fasteners in place. All that is missing is the straight edge casting. NO effort was made to make them look "pretty." You can see the ghosts of the dowel pins that locate the top blocks on the middle blocks.
Denis
Onshape Link
Denis
