In depth technical breakdown of CNC controls
ondori
Apr 30, 2019
I'm looking for any blogs, write ups, books etc. of in depth technical breakdown of CNC controls or machine motion controls.
I don't mean from a programmers perspective. But rather a real technical break down of hardware & concepts. Ideally I'd like something like a reverse engineer blog.
Any control is acceptable, from a FANUC to a Centroid or even Anilam, DX-32 etc.
I want to know things like:
On newer FANUC controls, hitting reset button will stop a running program completely.
On older FANUC 0i-TB, in order to stop the program you have to actually type M code. Hitting reset doesn't stop the program.
I discovered this when I used MDI to turn on the spindle of a VTL to test it, but when I went to stop it, the stop button only paused the spindle, the program is still being executed. Reset does nothing. You have to use MDI and type in an M-code to stop the spindle or stop executing the program.
At some point FANUC modified the function of the RESET button to stop execution of any program. I would assume that buried deep in the settings is a parameter that changes what the RESET button does.
However, I'm not interested in the RESET button, but rather how "machine code is executed". In a traditional automation system, we'd setup RESET button as a input, and program our logic to do whatever we want.
But it seems like FANUC has the "machine motion control" as an independent system, and any inputs are run thru some sort of interpreter.
They way I originally viewed CNC control systems, is as if they were really refined PLCs. I'm sure that given an infinite number of monkeys and infinite time, they could take a high performance PLC and make it into a fully capable CNC control. Technically, this is already being done. There's lots of other non-machining machines that have very complex motion.
I'd like to know things like: what is the low level operating system in a CNC controller (i.e. DX-32 runs it's interpreter on Unix and motion control is handled by the motion card).
All other PC based controls operate the same way i.e. Centroid which runs on Windows and outputs to a motion card.
What CPU architecture do they use? how does communication between drives work?
Garwood
Oct 10, 2009
Oregon
Buy all the Fanuc books for your control and read them.
WRT reset function that is likely a parameter. I've never seen a machine that reset didn't stop spindle and program. If I ran into that I would scan through the parameter manual looking for anything relevant. Likely it will be obvious when you run across it.
Vancbiker
Jan 5, 2014
Vancouver, WA. USA
Fanuc did not change the operation of the reset button in regards to your spindle issue. The machine tool builder determines what happens to anything controlled by their PMC ladder program when reset is pressed. Spindle control is handled by the PMC so if you want Reset to turn off the spindle you will need a ladder modification unless the builder provided a PMC parameter (KeepRelay) to do that. Depending on control and builder, you might be able to modify the ladder by yourself or you might have to request help from the builder.
There is no one architecture for CNC controls. Most Japanese CNCs use similar architecture though there are big hardware differences. The typical Japanese CNC is really 2 controls working together. There is the CNC and PMC/PLC (PMC is Fanuc speak for PLC). The CNC handles axis motion control, program and data management and execution. Software in the CNC is a product of the control manufacturer. The PMC controls all the machine peripherals. Spindle drive, Magazine, toolchanger, gearbox, coolant system, operation panel, you name it. The software for the PMC/PLC is a product of the machine builder.
CarbideBob
Jan 14, 2007
Flushing/Flint, Michigan
Interesting...:popcorn:
