BRIAN.T
- Jul 23, 2018
- Los Angeles
Inconel 718 isn't something I work with too often so I need some opinions.
Let's all just pretend this photo is the real part, it isn't, but it gets the idea across. There is a lot more going on with the real part.
This part will be done in a 5 axis, it it for the most part comprised of prismatic shapes, they are however all blended with a .187 radius.
I can finish about 40 percent of it just profiling with a bull mill, the upper diameter of the 4 "feet" and maybe 1/2 of the OD, however then I need to surface the remainder. This will lead to a bunch of mediocre blend issues. And inconsistent surface finish.
Alternatively I could surface the ENTIRE part, which would remedy the blend issues. And with a .187 fillet, I'm likely going with a 1/4 ball mill, but this will probably take about 14 hours.
What would you guys do?
