Index direction
Needshave
Oct 20, 2009
MA
I've recently started operating Kitamura 4 axis VMCs with 16i controls. I came from an area with 4 axis Matsuuras with YASNAC controls. The Matsuura "A" axis would always go past zero when indexing between positive and negative values. These FANUC machines take the shortest path. I would like to change the Kitamuras to behave the same way as the Matsuura machines. I've been looking at parameter 5500. Does anyone know what idx type A and type B change? The machine is currently set to type A.
PEGBOARD
May 19, 2016
Hi, what is Parameter 5500 #3(inc) and parameter 5511 set to. these are the two settings with regards to what you describe.
Needshave
Oct 20, 2009
MA
Thanks for the reply. Both are set to zero. 5511 looks like it sets a m code to use when going in a negative direction.
