DocsMachine
- Jan 8, 2005
- Southcentral, AK
I have a compact Trak mill, and I have several projects on the table that could use an indexer. I am quite ignorant of such things, apart from the general concept of how they work. (For example, the difference between an indexer, and a 4th axis.)
I'm told that both Haas and Hardinge indexers will basically plug right in- I assume others will, too, but those have at least been confirmed by the factory.
I'd like to have a better handle on what I'm after, before I drop the coin on one. Looking around at used ones online, I see some listed as 7-pin or 14 pin (which I assume is just the generation of the controller) with and without brakes, and either servo or brushless motors.
My table size is limited (2Op machine, about a 14" square table) and given my usual parts, a 5C indexer is fine. If I had my druthers (whatever those are) I'd prefer a Hardinge taper nose rather than threaded, simply because I have a 3-jaw and a couple pot chucks to fit. Threaded is not a deal-breaker, most of my pieces will be in a standard 5C collet.
Recommendations? Brands, models or generations to look for? High-number production isn't a key issue, so I don't need the latest-and-greatest, lightning-fast version. Affordable is more important.
Thanks in advance.
Doc.
Thanks in advance.
Doc.
