Insert tooling size
Andeo1025
Apr 30, 2022
I finally mount my qctp to my sb 9a last night. Now I'm looking at insert tooling and it seems my options are 3/8 or 1/2 in tools. The axa holders I have will hold a 1/2 in tool, but I'm seeing that I may not be able to line up centerline with that size. Which size am I better off with? Thanks for the help.
SteveM
Sep 22, 2005
Connecticut
I just checked my 9a using a 1/2" toolholder with a TPMG insert and I can get it below center.
If you don't have any toolholders yet, get a piece of 1/2" bar stock and see where it sits.
I have an assortment of 3/8" and 1/2" toolholders.
mattthemuppet
Apr 22, 2016
San Antonio
There's not much need for 1/2" shank tools unless it gets you an insert or angle that you can't get with a 3/8" shank tool. If you want to get started if suggest a 3/8"/ 10mm SCLCR turning tool and boring bar, and a pack of CCGT0604 inserts. A little fragile but very free cutting. They'll do pretty much anything you need, but for nasty stuff you can pick up a pack of CCMT inserts for little money
SteveM
Sep 22, 2005
Connecticut
Another reason for CCxx inserts is that there are TONS of them available on ebay.
CCxx are most of my inserts, but I also have some V inserts for tight places. I have some T inserts, but I generally stick with the Cs.
