Orange Vise
- Feb 10, 2012
- California
One of our DMG Mori HMCs has a pallet pool that works entirely with hydraulics. The APC is simple with the following functionality:
1. Index to any pallet position
2. Tilt up/down
3. Extend/retract
We're having an intermittent issue where the unit is pausing while tilting down in the extended position after moving a pallet. This happens immediately after the pallet makes contact with the rack and the APC is unweighted.
You can hear the hydraulic pump cycling continuously trying to maintain pressure (pressure keeps dropping). Eventually it times out and I have to recover manually. Hydraulic pressure stops dropping at this point.
Recovery is easy. Most of the time I simply tilt-down all the way, retract, and clear the errors in the control. Sometimes I have to tilt up first, then tilt back down, and retract. I'm guessing the hydraulic cylinder is binding and needs to be replaced. Simple enough if that's the case.
Am I missing anything? I'd imagine this pallet pool design is not unique to DMG Mori.
Thanks.
2. Tilt up/down
3. Extend/retract
Thanks.
