I have 2 interapid indicators one .0001" and one .0005". I use them all the time and really trust them. I recently upgraded to number of noga mag bases, the steel arm and also the articulating type. My previous Chinese articulating type had the the adjustment at the end of the arm and I would constantly get flutter when measuring.
Well I set up to dial in a chuck backplate with the beefy steel arm noga base, and the interapid .0001" indicator. The backplate has a very nice surface finish. When I started trying to dial it in as close to .0001" runout as I could get I noticed the indicator was drifting clockwise after the part stopped moving. I was able to replicate the drifting with both indicators, all 3 noga bases, the backplate as well as a ground 1/2" gauge pin.
Here is a video of the needle "drifting". You can see as I stop rotating the chuck the needle drifts a few tenths clockwise.
Is this somewhat normal at this measurement level, or are my indicators damaged? I don't think I ever previously noticed this phenomenon as my previous base wasn't stable enough and I'd always have a little needle bounce going on. That, or the surface roughness of the part would induce needle bounce on its own.
Any ideas?
Any ideas?
