Is SPI Any Good??
tmthy21
Feb 26, 2023
Hey All,
Been looking at buying some SPI Mechanical Micrometer Style Calipers
here's the links to both
Mitutoyos Sets in this size range between $230 and $250 while SPI is $117 and $125
im a big Mitutoyo guy and my mics and calipers are all Mitutoyo thus far, however id like to get a set of thread mics, disc mics and blade mics at some point as well but the prices for Mitutoyo range between $250 - $450 depending on the type, With SPI being $200 - $350
im a Swiss guy and I don't use those types of mics too often, as well as those mics that I posted above,
Ive heard a lot of people crap on SPI and I've never used them myself, there calipers do look cheap compared to Mitutoyo,
Just Wondering if anyone has owned or does own any of these special types of SPI Mics, should I spend the extra $200 on these types of mics or give a shot to SPI
I know MSC Owns SPI now but I've seen mixed Reviews,
Thanks guys
- Timothy
yoke
Sep 26, 2013
PA
I have an SPI flange mic and it works for what I needed it for. I only use it once a year and am measuring extruded fins, so not tight tolerance work. I am a Mits guy myself and wouldn't trust the SPI for the really critical stuff.
You'll get what you pay for so if you will use it a lot you should pay more for better quality.
doug8cat
Jul 10, 2008
Philadelphia
I too am a Mits and older starrett metrology guy. I have and do use a couple SPI veneers they are okay a bit stiff compared to the mits. I go for the Mits first then micrometers when measuring is critical to .001 and finer.
Cyclotronguy
Sep 21, 2005
Northern California
My experience with SPI has been 'variable". Quality ranges from average European to "run of the mill" Taiwan. If you only need 0.001 Inch or 00.02mm resolution, then SPI will be fine for occasional use.
LatheLover91106
Feb 6, 2023
Hey All,
Thanks guys
- Timothy
SPI is a good enough brand do get you through your day to day job and will probably last a while if you maintain them. but if your looking for reliable tools that will last a lifetime i wouldnt choose SPI, if your going for cheaper i would choose Fowler or Browne and Sharpe. I stick with Starrett and maybe a couple Mititoyo . But SPI is mid grade...good enough for +/- 0.002" id say
doug8cat
Jul 10, 2008
Philadelphia
I agree with RJT. for my money I would go with Mits or Starrett. That being said I have a pair of no name very nears and they are fantastic, for my purpose.
gregormarwick
Feb 7, 2007
Aberdeen, UK
It's important to understand that SPI do not manufacture anything they sell, and everything they sell comes from multiple sources. Some SPI tools are absolute garbage that I wouldn't give to the most unworthy apprentice, while some are perfectly fine. You won't know which you're going to get until you get it.
I have a boxed set of SPI three point internal mics from 50-100mm with setting rings. They are made in Taiwan I am fairly sure. Construction is good, accuracy is good, finish is not as nice as Tesa, but nipping at the heels of Mitutoyo. Gauge rings pass calibration no problems, wooden box is nice...
On the other end of the spectrum I bought an SPI indicator mag base for an apprentice and I didn't even send it back, it went straight in the bin for fear of some other poor bastard ever having to use it, and the indicator I bought with it followed shortly afterwards.
M.B. Naegle
Feb 7, 2011
Conroe, TX USA
I'm in agreement with the above. SPI is sometimes average and other times poor. IMO the name dosn't command a lot of repsect. "Swiss Precision Instruments" IMO is about the same as some of the Asian import stuff they come up with like "New Bright." "Insize" is another, though their stuff tends to be OK.
IMO it's one of those Name Brand vs. Off Brand things. The caveat is that it's not literal. Just because the tool has a name on it doesn't mean anything. It's a matter if the company is actually doing some work under that name, more than guys in an office buying and selling and guys in a warehouse changing labels. If they at least test inspect and support the product, that's better. Making it themselves tends to produce the best results.
Sometimes you get some exceptions though. I've always liked the old Miller Falls stuff, and most of that was made under contract, not necessarily by MF employee's, and General still makes good stuff, despite the name.
Starrett or Mititoyo over B & S???
Regarding the OP i have no experience with SPI metrology equipment, but my R & A Dresser is that brand.
It is better thought out and more intuitive to use than many; better capacity than some. Very nice, solid to use - would absolutely buy that unit again for my purposes. OTOH as others note about SPI in general, not quite top drawer in fit, finish,feel.
smt
guythatbrews
Dec 14, 2017
MO, USA
I agree SPI is hit or miss. Like most everybody the new stuff has plastoc parts and I won't have that.
If you like MIT watch ebay. Be patient and you'll find what you want. The green hammertone tools are better. I don't buy anything with the least sign of wear or abuse, and steer clear of marked tools if I can. When you receive them check em out close. Send them back if you are not happy.
Be patient and you'll get good stuff and save a ton.
majohnson
Jan 3, 2013
Erie, CO
As others have some are good; others not so. If it something you are not using it veryd often they might be ok. Get out your gage block set and check it in several different spots. Once you figure out what your error factor is over the different places, note it down and put it in the box with the tool.
If you do not get you measuring tools calibrated, it a good idea to check them all. Other wise you don’t know that your actual part sizing is correct.
